I am making a kegerator from a Kenmore Refrigerator Model: 253.6480240E, is it possible to cut holes (probably 3 holes) in the side without damaging any of the electrical or coolant lines?
I am thinking the right side if you are facing the refrigerator.
Originally Posted by: charbor ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am making a kegerator from a Kenmore Refrigerator Model: 253.6480240E, is it possible to cut holes (probably 3 holes) in the side without damaging any of the electrical or coolant lines?
I am thinking the right side if you are facing the refrigerator. Charbor, I've seen it done before, several times, On that style refrigerator, I would reccomend, you drill your holes 3 inches back from the front flange of the opening and 3 to 4 inches down from the bottom of the mullion strip (the metal strip separating the 2 compartments). you don't have a lot of "fudge" factor(1/2 to 3/4 of an inch), but I would think you'll be fine with those measurements. :) :) :)
Joe, Thanks for the information and the quick reply.
Originally Posted by: charbor ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Joe, Thanks for the information and the quick reply. Charbor, You're welcome and Good Luck, you should be fine. :) :) :)
