Originally Posted by: mea  Hi Joe,
First of all there was standing water in the bottom compartment. I think it's supposed to be that way. Please confirm.
There really wasn't debris, but there were 3 small smooth flats stones. All the same color and size. Are those supposed to be there?
Thanks again for your help. Mea, No, there should not be any "stones" of any type, inside the dishwasher or mechanisms. As for the water level, You should not be able to see any water in the bottom of the tub. There will be water left in the upper area of the pump assembly, but when the pump cover is installed, you wont see it. Remove the stones and check the drain hose for clogs or kinks.( disconnect the drain hose from the disposal or kitchen drain, and drain the dishwasher to clear any possible clogs or debris in the hose). :) :) :)
