Just purchased new insert for control panel. Part #WPL 9744468. Does the front cover come off to install or do you just pull old one off and apply new. I believe the back of the new insert is self adhesive.
Help is appreciated.
The part number you posted is for the water inlet valve. In order to replace the insert (#2 on the break down diagram) you have to remove the console and take it apart. Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS24SEBL1Gene.
