Dishwasher cleans ok but the wash and rinse cycles seem to be very long. It has just recently gotten very noisy. Heat elements seems to work as water is very hot and dishes dry. I replaced heat element 2 years ago. I cleaned and inspected both chopping blades and removed some glass but still very noisy. Almost sounds like pump/motor is spinning too fast but it drains ok.
Does anyone know what the cycle times should be and also how to check if there is a 2nd washer impeller that might be starting to fail??
Any Ideas??
The motor bearing in this pump motor is known as a noise creator. The solution is to replace the motor assembly or the whole pump & motor assembly. The difference in price is about $40 but the pump & motor assembly is much easier to install.
The end of the model number you posted is incorrect, so if you need the correct part numbers, verify and repost the model number.
