rmything
#1 Posted : Friday, February 6, 2009 7:09:11 AM(UTC)
rmything
Water is getting into my washer while it is off. I used the drain setting and drained it but a couple of hours later I can see water starting to show up in the bottom of the drum. This is a front load washer and has been a very good washer. This is the first problem I have had with it. I have had it for about 2 years. Any help or suggestions would be awesome. I am assuming there must be a seal that is gone somewhere but don't know enough about how these things are put together. Thanks
#2 Posted : Friday, February 6, 2009 7:59:35 PM(UTC)
Most likely the problem is the water inlet valve stuck open. This part has to be replaced. The model number you posted does not come up. Verify and repost it.
rmything
#3 Posted : Saturday, February 7, 2009 6:51:40 AM(UTC)
rmything
that is the correct model number it just doesn't come up on your site. I tried it on anther site and the model number worked. Thanks for the help I will replace the valve and let you know if it worked.
