The icemaker is not producing any ice? I've replaced the complete icemaker with a new one #2266836 left alone for 24 hrs. and checked and still no ice. I then even doubled checked all of my connections to make sure it was installed corectly. There seems like there is no water being dispensed through the water tube at the top of the refrigerator. I've take a very small diameter wire and gently tried pushing it up into the tube to see if it was clear and there seems to be soild, like if there's no hole? Can any one help?
Have you replaced you filter? GE told me to replace mine and it should make ice.
Yes. I just installed a brand new one.
