AppliancePartsPros.com
Appliance Repair Help
Washer Repair
front loader major noises during spin, water leaking on floor
Makes creaking/ squeaking noise sounds like bearing when I ture the drum by hand but it also makes it and a loud banging noises during spin when the shocks are really moving and to top it off there's water leaking onto the floor. Removed lower front panel and it looks like the water is leaking towards the back so does a seal fail when a bearing goes out. Please help and thanks. I mean really three problems all at once. Should I find the nearest cliff and push the washer off.
If the bearing is gone, and it sounds like it is, then you do need to go cliff hunting.
At this point with your machine a replacement is the best option.
Originally Posted by: sidfink43  If the bearing is gone, and it sounds like it is, then you do need to go cliff hunting.
At this point with your machine a replacement is the best option. OK, that's what I thought. I understand that some of these machines are prone to this type of failure. Thank you very much for getting back to me it means alot.:cool:
No problem, yes this machine is very prone to the problem you have.
Good luck with your new machine.
Washer Repair
