Kenmore Elite Slide-in model with glass top displays "56" on all stove top burner displays. Tried to recycle power. I can only lock and unlock oven door. Oven and misc. controls do not respond. Could not unlock stove top controls after locking it by pressing clock button. I have a "SA6" display next to the time display. Anyone know what could be the problem(s)?
Talked to a tech expert who said the "SA6" means sabbath and could be cleared by pressing the clock button for 30 seconds. I then got an "F11" error message which he said it means a shorted keypad for the control board. I could also keep the power off for 72 hours which would reset and turn off the sabbath mode and the oven will work. Any comments?
This is the sabbath feature and can be disabled by pressing both the (timed oven) "cook time" and "delay start" buttons at the same time for approx. 3 seconds.
