AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer runs for a while then all electric stops.
Dryer will run and then it just stops. When you open dryer door no light no electric. After a while you can hit the start botton and it will run.. Help
Sounds like the connections are eroded or loose. First, check the power coming from the outlet. Then check the connections at the wiring terminal. (Don't touch them unless the dryer is unplugged).
Dryer Repair
