I have what I think is a common problem with my Thermador double electric oven. The oven is working, but the control panel is very faint to blank. There seem to be a number of parts that might be the fix, but I can't tell which precise part I need. Also is this a do it yourself job by a smart husband and son-in-law if instructions are provided? Thanks.
The correction is to install the control kit which contains of the display board, the power relay board, the wire harness and the complete installation instructions. This job is not going to be too difficult for the man you described. - The part number for the control kit is AP3382408Here are the break down diagrams for the Thermador oven Model SC302TGene.
