dryer will not come on at all. tested power and it is fine tested door switch no problem what to do now:p :p
I have and Admiral Dryer with the same problem. I've been able to confirm power to the dryer, but that's it. The light doesn't come on, nor does the dryer in any way. Timer still runs. Help!
Hi Brown, I owned a dryer that exibited the same things that you are describing here. I took the whole dryer apart (out of frustration) to find out why. I found that the motor had seized up. Hope this helps, kenmore
