GE Dishwasher GSD5930d01ww runs through the cycles, sounds like it is emptying on every cycle. However on the final cycle it does not empty the tub. I have replaced the vavle assessible from the inside (back) and cleaned all the screens. Still the probelms persists. I unplugged the solenoid and ran an ohm meter on it. The reading came back 00.0. I want to exhaust all possibilities before pulling the dishwasher out for closer inspection.
Any suggestions?
Washer kicks out breaker when filling with cold or hot water
Originally Posted by: adans-sandra@att.net ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Washer kicks out breaker when filling with cold or hot water[.../quote]
