Julie0012
#1 Posted : Thursday, May 19, 2011 6:00:45 AM(UTC)
Julie0012
I purchased from this site part # AP4097628, which is called the clock with the harness. I think this part is the control board. When the oven was turned back on by the breaker, a F1-8 message appeared with beeping, just like before I replaced the part.
The initial problem with the oven was that it had started beeping and displayed a F1-8 message. By replacing the control board, I thought it would fix the problem, it did not.
Now I think I need part # AP4094865, which is the control panel assembly. Before I return the control board which is now taken out and in its original box, I would like to know for sure if I need the control panel.
When reading other forums, I found out that someone else had a F1-8 problem, which meant a shortened key in membrane switch. So I opened the control panel removed the ribbon cable from the control board and have cleaned it with an eraser, and checked the ribbon with a magnifying glass.
When I checked the ribbon with a magnifying glass I found that across the entire ribbon there was a crease (please see drawn attachment). I would like to know if the crease is normal or if this is an issue and I need to return the control board and then purchase the control panel.
Also when performing the F1 touch pad / ERC test the message displayed F1-7, what does that mean?
Please advise me to which part is needed or any other suggestions. Thank you in advance for your time.
Julie0012 attached the following image(s):
Joe / APP Team
#2 Posted : Thursday, May 19, 2011 6:32:36 AM(UTC)
Joe / APP Team
Julie,
Both fail codes, and the crease in the touchpad ribbon, indicate, the keypad ribbon is the problem.
F1-8 indicates the ERC control is " seeing " a constant circuit from a keypad.
F1-7 indicates the ERC is not"seeing" a circuit from the touch pad assembly.
Both codes could and probably are due to the crease in the touchpad ribbom.
You'll need to call our Customer Service Dept. 1-877-477-7278 , and make arrangements to return the control/ERC and order the Control Panel assembly,
Part number: AP4094865
Good Luck,
Guest (4)
