I have a Frigidaire Gas dryer that after doing some research here..I do believe the Gas Valve Coil(s) are shot. I can see the burner light..then it will just shut off. Sometimes it dries good..most time the burner just doesn’t light. My question is how do I get to the coils? Of course I left the model of the dryer home but I can say it a cheapo $400 gas dryer bough about 5 years ago new. There’s what looks like a vent plate on the lower left (if you’re looking at it from the back) I removed that and the motor is right there. I can see the gas valve and burner assembly all the way to the right but can’t get to it from there. I removed the top but there’s no way I can get to it there. There’s no access panel anywhere near the burner. DO I have to go in through the bottom? Thanks!
Unfortunately we can not proceed with any advises without the complete model number.
