barbara witkowski
#1 Posted : Wednesday, May 18, 2011 4:56:21 PM(UTC)
barbara witkowski
washer makes a excessive high screaching sound when in spin cycle. I need to know if it is the motor, or the bearing and if it can be replaced.
sidfink43
#2 Posted : Thursday, May 19, 2011 5:54:00 PM(UTC)
sidfink43
It is the bearing, it can be replaced with special tools and special parts or the tub assembly can be replaced which is very expensive.
When this happens I always say to replace the machine. Many, but not all who do not take this advice regret it.
If you have gotten a good long term out of this very troubled model count yourself very lucky and celebrate with a new washer.
Lr code on my Maytag Neptune Front Load Washer (Washer Repair)
by Guest 11/19/2022 9:53:55 AM(UTC)
Maytag Neptune Front Load Washer “do” code (Washer Repair)
by Guest 12/25/2021 2:22:33 PM(UTC)
Maytag Neptune front load washer MAH7000AWW (Washer Repair)
by kerrlakecrappieman@gmail.com 3/16/2019 7:53:32 PM(UTC)
Maytag Neptune Front Load Washer Squealing (Washer Repair)
by ArcadeMan 2/10/2014 10:31:10 AM(UTC)
by debbierocks 4/1/2012 6:59:03 AM(UTC)
maytag neptune front load washer (Washer Repair)
by lbrennan 3/12/2012 12:36:33 PM(UTC)
Need Help with a Maytag Neptune front load washer....stops running at each cycle. (Washer Repair)
by carebear03303 2/11/2011 6:43:15 AM(UTC)
by gmhandel 9/18/2010 4:57:34 PM(UTC)
Maytag Neptune Front load washer (Washer Repair)
by mnunno 2/26/2010 1:15:35 PM(UTC)
MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet (Washer Repair)
by debbielf 8/31/2009 8:05:14 AM(UTC)
Maytag Neptune Front Load Washer Help (Washer Repair)
by debster101 7/23/2009 1:03:06 PM(UTC)
Maytag Neptune front load Washer (Dryer Repair)
by castillocm 7/31/2008 4:03:24 PM(UTC)
