Scotty dishwasher doesn't
#1 Posted : Wednesday, May 18, 2011 11:49:36 AM(UTC)
the dishwasher won't start to cycle througha wash, when I push the cancel/drain button the moptor starts up, but doesnt cycle through the wash, soon after it quits and the clean light is still blinking... Help
Joe / APP Team
#2 Posted : Wednesday, May 18, 2011 12:53:01 PM(UTC)
Joe / APP Team
Scotty,
The blinking clean light indicates a water heating problem,
PROBLEM: Stopped Running, Will Not Start and Clean LED
Blinks 7 Times, then Repeats (Water Heating Fault)
Most of the time , it's due tp a low water temperature(minimum of 120 dgrs. in the tub on the first fill) but could also be a part malfunction( open heater circuit, hi limit thermostat or loose wire connection.
You'll need to reset the control board,
To invoke the Diagnostics Cycle, perform
the following key presses or actions in less than
6 seconds while in standby mode:
Heated Dry
➙ Normal ➙ Heated Dry ➙ Normal
Allow the control to run the whole diagnostic cycle(takes 5 to 10 minutes)to off.
Run the hot water faucet at the kitchen sink, to flush any cold water from the pipe and start a new cycle. If the clean light is flashing again, you'll need to run circuit checks on the heater element and thermosta and wires.
Good Luck,
