dalek
#1 Posted : Wednesday, May 18, 2011 6:05:18 AM(UTC)
dalek
Quick question: I ordered the agitator repair kit for my washer part # AP3138838 (285811) -- the dogs are clearly worn and not working. The description at AppliancePartsPro suggests i also use agitator grease. My question is: where does the grease go? :confused:
Dale
Joe / APP Team
#2 Posted : Wednesday, May 18, 2011 6:34:03 AM(UTC)
Joe / APP Team
Dale
Dale,
I've used a small amount of grease on : the dogs, the cam,thrust washer and bearing you only need a "dab" on each part, and use a dab on the "O" ring, on the cap, to help ease the install of the cap.
Good Luck,
