Been having dryer issues it stopped working a few days ago I took it completely apart and found a sock in the blade part of the vent removed it and put the machine back together it now works but there is a loud knocking noise i had some issues with the belt it felt loose at first then I changed and kind of doubled it around the pulley. should the belt fit snug or loose could it be a problem with the belt:confused:
the belt could be your issue. i would replace it. tom [url=]applianceeducator.com - parts[/url]
