hectorabuyen
#1 Posted : Tuesday, May 17, 2011 11:03:06 PM(UTC)
hectorabuyen
My LG dishwasher keeps showing an "IE" error code which pertains to water not entering the machine. I just replaced the inlet valve and it still shows the error code. I tried purging the air by filling the tub manually with water and it worked for a complete rinse cycle, but showed the error again during the last rinse of the normal cycle. I know that there is a guide assembly which has the float and two micro switches that I haven't checked. I am puzzled why it works intermittently. What should I check. Thank you in advance for any help you can give.
Sincerely,
Hec
Sicarbide
#2 Posted : Monday, January 23, 2012 8:25:12 AM(UTC)
Sicarbide
Sincerely,
Hec
Let me know if you found the problem. LG LDF6810BB is doing the same thing. I replaced the inlet valve and the guide assembly (Float assembly with Air Breaker) on side of machine, but it still gives error IE or 1E.
I installed a new supply hose, I know there is water to the intake valve.
Funny thing is the owners manual states that this IE error occurs when the DW has run for 10 minutes and the fill level has not been reached.
The IE error comes on and machine stops AFTER ONLY 1 MINUTE of the cycle.
Any help?
Guest
#3 Posted : Thursday, March 24, 2022 3:10:41 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Did you figure out your problem? I am having the same issue.
Guest
#4 Posted : Friday, September 15, 2023 9:14:17 PM(UTC)
Guest
Rank: Guest
Groups:
United States
Same here. The washer fills, like it should, it. Just direct think it’s filled. Then error code IE comes up, drains ends. Ugh. Already replaced the brain in this a few years ago. Only 6 yrs old average usage, ugh
Edited by user Friday, September 15, 2023 9:16:48 PM(UTC)  | Reason: Wordy lol
Guest
#5 Posted : Wednesday, April 24, 2024 5:35:37 AM(UTC)
Guest
Rank: Guest
Groups:
United States
My lg dishwasher is showing IE after few minutes of starting and the dishwasher stops. What can be done?
