Hi, My washer runs through the complete wash cycle, but when it comes time to spin it just turns slow and back and forth like the wash cycle. I ran the diagnostic test and at C:08 it spins at high speed counter clockwise like it should. What could be my problem? the CCU?
I think it is fixed. I cleaned the drain pipe to the drain pump and the hose to the drain and all is working fine again. No cost... hope this helps someone.
