Problems started about 2 months ago.I had a serviceman out who said the main computer board was shot but never called or came back.After some testing I decided that perhaps that was the problem and changed the board.I still had a problem and did a self diagnostic check which came back "refrigerator fan error".I changed thefan and three week s later it has froze up solid on the fridge side once again.I ran a test again and on led's are lit up.I have had this panel apart about 5 times and have broken the styrofoam insulation in about 4 places.I have tried to superglue this back togetheras best as possible but it is not in very good shape.Could this be the problem? Thanks.
Here are your parts Model RS267LASHHere is a service manual which may help http://www.servicematters.com/m...library/docs/SAM0074.pdfit has froze up solid on the fridge side once again. Not sure what your problem is. Are the evaporator coils in the fresh rood section heavily iced up indicating a defrost problem? I ran a test again and on led's are lit up. Also not sure what this means. Unfortunately my puter will not let me open the service manual, something about a Japan1 font. So I will have to fix that before I can look at the manual. |
THIS FORUM IS DEAD!!!!!!! |
