Is the The igniter normally closed,or only half closed,I use the meter show only half. do I have to be replaced.
Originally Posted by: sun888  ...only half closed... Can you explain what did you mean? What is the complete model number of the dryer? Gene.
Frigidaire 417.59012890 Clothes Dryer, My dryer is not giving off as much heat as it's suppose to be. It started to take longer to dry the clothes. The flame sensor ,the safety thermostat ,and the heat control thermostat are normally closed, I can see the glow from the ignit, and the ignitor appears to turn off after 10 secs. I used a meter to check the igniter and the needle landed on the 3k OHMS , do I have to replace it?
Sorry for the delay.
The most common cause for such problem is restricted air flow in the exhaust line. The first thing I would do is clean the exhaust line from the dryer all the way through the outlet.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I replaced all those parts and nothing
