I'm having a problem with the icemaker. First, there seems to be a leak (as ice forms outside the tray and on a tube to the icemaker). Second, the solenoid sticks and we can only get crushed ice. I can manually move the solenoid, but it gets stuck (maybe freezes?) again. Last, some of the ice actually has frost on it after being dispensed. I'm guessing that this is happening due to moisture.
Any suggestions?
Thanks.
If it's less than a year old have a GE tech repair it under warranty.
Nat
It's atleast 5 years old so that's not a possibility.
