I have a problem with spin cycle. It doesn't work on regular cycle, but does on the other cycles. What are the possible problems? I consulted Maytag FAQ's on their website, but not helpful. Is it the timer?
Originally Posted by: klawson ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a problem with spin cycle. It doesn't work on regular cycle, but does on the other cycles. What are the possible problems? I consulted Maytag FAQ's on their website, but not helpful. Is it the timer? I have the same problem with a LAT 731 4AAE. What did you find out? Thanks, Tom
Most likely the problem with your washer is a bad timer. - The part number for the timer AP250048 - Here are the break down diagrams for the Maytag washer Model LAT7314AAEGene.
