Came back from a trip. Time flashing on Maytag Gemini Double Oven. Turned on Broil on top oven. Flashed for a few seconds and then something like 5EE came on. I pressed Cancel but same thing happened on Broil. Bake works. Tried lower oven. Same Code. Went to the circuit breaker. Turned off power. Turned back on. Same problem. Would appreciate any thoughts on what has happened. Thanks.
THIS FORUM IS DEAD!!!!!!! |
