AppliancePartsPros.com
Appliance Repair Help
Washer Repair
makes loud banging while in spin, does not spin fast
I was hoping that I can repair it myself. I took the back off and notice the loud banging noise is coming from inside the plastic drum surrounding the inside steel drum. I took off the big wheel that attaches to the drum but I can't get into the plastic drum this way (i was hoping I could) Sounds like something is loose or broken inside drum. Could you please explain to me what is happening in there.
Thank you
Tilt the top back and remove the plasctic tub top and fish out the item with a coat hanger.
Washer Repair
