The pump seized on the washer and the belt spit black rubber against the walls of the washer. So I replaced the water pump. The washer belt is another story. I'm unsure about the cam part of it. I know you remove the 3 metal struts (once the washer is laying on its front), there is that cam mechanism that I'm unsure about how you take that apart (at the top of the transmission). There is a small bolt with a ^ on it that you unscrew after you spin the large pulley and it comes all the way to the top. BUT there is something with a cam shaft rod and a spacer???? that I'm not grasping. The illustration on the belt bag but it SUCKS!
Please advise me, Thank you!
