John_C
#1 Posted : Thursday, November 1, 2007 8:21:32 AM(UTC)
John_C
My dryer has gone completely dead. I had some clothes drying, and when I turned the dryer off, I heard a clicking or popping sound. After this, the dryer was completely dead; the inside light doesn't even come on. I checked the circuit breaker, and it had tripped. I flipped the circuit breaker back on, but the dryer is still dead. I would appreciate any ideas about what's wrong, troubleshooting suggestions, or any other advice as to what I should do next. Thanks
#2 Posted : Friday, November 2, 2007 2:24:53 AM(UTC)
Should be an easy fix. Remove back plate over pigtail connection and look for a blown wire.
If ok, remove back panel and look for a burnt wire. If ok, remove front panel and drum and look for a burnt wire.
tombie
#3 Posted : Friday, January 18, 2008 10:36:57 AM(UTC)
tombie
My dryer same model was fine yesterday, but won't start today. It has power, and is not making any noise. Any thoughts?
