Please Help,
While watching the Exorcist on Halloween night, and during a scene where the furniture was flying around Linda Blair's room, my oven starting hissing and sparks began to fly inside the oven. The control display went blank and I could not turn the oven off.. Very scary. However, I did manage to shut off power to the unit and have since removed the melted heating element from the lower part of the oven compartment. It was melted half way through. Obiviously I need to replace the element but what about the control panel? Is there some sort of fuse I need to replace or is my oven shot?
P.S. Holy water didn't help.
Dan Restis
first of you will need a young priest and an old priest..... but seriously, it sounds like you will need to check a couple of items. the control board and the thermal fuse as well as replacing the element. your model # doesn't seem to come up. re-check the model # on the oven and repost it here
Hey thanks for the quick reply,
The model for my Amana self cleaning electric oven is Model#ART6600LL and the serial # is 9512169248
