richcanfixit
#1 Posted : Tuesday, January 27, 2009 7:50:45 AM(UTC)
richcanfixit
I have A Kenmore Range showing an error code F31. Can you tell me what this means. Can not find it in any of the charts.
kayakcrzy
#2 Posted : Tuesday, January 27, 2009 12:40:02 PM(UTC)
kayakcrzy
the first thing you need to do is check the oven sensor. it should ohm out to about 1100 ohms. the sensor is the thin rod, that is in the back of the oven up top. the part # is 316407700. if all is well there, then you will have a bad clock control board. part # is 316418208. tom [url=]applianceeducator.com - parts[/url]
Error code F31 (Oven Repair (including Ranges and Cooktops))
by Zanesmom310 11/8/2011 12:27:22 PM(UTC)
Kenmore elite oven error code F31 and F5 (Oven Repair (including Ranges and Cooktops))
by defcon4 1/31/2010 7:58:03 PM(UTC)
