industrial_elec
#1 Posted : Tuesday, January 27, 2009 7:10:15 AM(UTC)
industrial_elec
:confused: Kenmore series 70 washer will not agitate or spin i will try to list what happenes when unit goes through a cycle
set timer turn on:)
water fills ok:)
the motor comes on and is running through wash cycle but no agitation:mad:
after wash cycle water draines:)
after water draines motor comes on to spin but tub does not spin:mad:
tiner advances to off:)
:confused: I need advice on whare to go from here the following is a list I have done so far
lid switch checked out ok
coupler cheked out ok
motor ok
agitator can not be turned by hand
Is this electrical or mechanical problem?
how to west transmission and clutch?
what else could it be and how to troubleshoot?????
:) Thank You in advance for the quick reply. any and all suggestions greatly appreciated evan if it is not the answer to my problem it will be the answer to someone elses!!:) :) :) :) :) :)
:mad: :mad: there is alot of laundry piling up :mad: :mad:
boseman75
#2 Posted : Monday, August 6, 2012 2:21:16 PM(UTC)
boseman75
I think this is the same problem I am having...any resolution?
