Actually, I'm told the stove is a Hotpoint.
I've got an Invensys oven control board that is dead. No clock, can't turn on the oven (everything seems dead)...nothing. I'm looking for some help with the troubleshooting or a schematic for the board. The only number I can see on the board is: CPC-E 94V-0 , Date code 48-03.
Any thoughts?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Oven microwave GE WALL unit. Everything works on panel for oven when pushed. Problem is oven don't heat. Both elements and sensor replaced. Fuse is good.sP5sJpZG
