vtrash@hotmail.COM
#1 Posted : Monday, January 26, 2009 1:23:28 PM(UTC)
vtrash@hotmail.COM
when it is turn on it takes in water but does nothing afterwards, i.e., the motor does nto run, then I smell like motor is burning so I shut it off immediately.
Sounds like motor is bad; is it right? where can I but the motor?
Vincent
any instruction as to how to remove old motor and replace with new one ?
#2 Posted : Wednesday, January 28, 2009 1:17:14 PM(UTC)
Most likely the pump & motor assembly has to be replaced. You have to remove the dishwasher from the cabinet. The new pump& motor assembly comes with the complete installation instructions.
- The part number for the pump & motor assembly is AP2616850
