saintsnik
#1 Posted : Tuesday, May 10, 2011 3:38:22 PM(UTC)
saintsnik
Hi I have a GE GSS22JEPAWW that went into defrost or something stopped working. The compressor is still working and i think I've narrowed it to one of these 4 parts.
- The part number for the main control board is AP3950129
- The part number for the freezer thermistor is AP3185407
- The part number for the defrost heater is AP3183868
- The part number for the defrost thermostat is AP3884317
Which is the most logical to start with?
#2 Posted : Wednesday, May 11, 2011 1:34:30 AM(UTC)
I would first verify the compressor is running, it should vibrate and the condenser tubing should be hot.
saintsnik
#3 Posted : Thursday, May 12, 2011 12:50:09 PM(UTC)
saintsnik
I turned it off completely for 24 hours then turned it back on.
It's working again now. It is vibrating a little bit and the tubing is hot.
Of course I'm nervous to put anything back in it.
Does that help you narrow it down at all?
#4 Posted : Friday, May 13, 2011 1:53:03 AM(UTC)
It may have hung up in defrost, so I would check the evaporator thermistor, a white narrow plastic item clipped to the top of the evaporator. If immersed in ice water, it should read 16.3 k ohm.
If ok, I would pull the motherboard in the back and check for bad solder joints at the big power relay.If ok, probably a bad motherboard AP4436216
Red Bull Mini Fridge problems (Refrigerator & Freezer Repair)
by itsconstable 2/28/2016 12:32:59 PM(UTC)
maytag fridge problems (Refrigerator & Freezer Repair)
by BILL 3RD 8/28/2014 8:38:54 PM(UTC)
Whirlpool Side by Side Freezer and Fridge problems (Refrigerator & Freezer Repair)
by briant97 3/2/2011 3:11:17 AM(UTC)
Samsung Fridge Problems (Refrigerator & Freezer Repair)
by KatHorner 11/16/2009 10:26:21 AM(UTC)
profile fridge problems (Refrigerator & Freezer Repair)
by Sovrafa 11/17/2008 12:34:43 PM(UTC)
Amana Fridge problems (Refrigerator & Freezer Repair)
by gehrhart 7/25/2008 3:05:40 PM(UTC)
Freezer fridge problems Montgomery Ward (Refrigerator & Freezer Repair)
by Em in Maine 6/24/2008 5:08:10 AM(UTC)
