gaw37130
#1 Posted : Monday, January 26, 2009 11:13:52 AM(UTC)
gaw37130
THE TIMER ON THIS DRYER STOP WORKING CORRECTLY WHEN THE FABRIC SLECTOR SWITCH IS IN THE NORMAL OR HIGH POSITION AND THE TIMER IS SET TO THE AUTOMATIC SETTING. tHE TIMER WILL NOT MOVE AND THE DRYER WILL JUST CONTINUALLY RUN. iF YOU MOVE THE FABRIC SELECTOR SWITCH TO THE PERMANENT PRESS POSITION THEN THE TIMER FUNCTIONS PROPERLY. i HAVE REPLACED THE TIMER AND THE SWITCH AND IT IS STILL OPERATING THE SAME. WHAT ELSE CAN I CHECK TO CORRECT THIS PROBLEM.
THANKS,
GARY
#2 Posted : Tuesday, January 27, 2009 3:57:09 PM(UTC)
Gary,
I would recommend to replace the cycling thermostat and the thermostat heater (under the thermostat). They are mounted on the blower housing.
- The part number for the cycling thermostat is AP4053749
- The part number for the thermostat heater is AP4070513
