vz223
#1 Posted : Wednesday, October 31, 2007 4:41:57 PM(UTC)
vz223
Just installed a few days ago. Noticed water left in bottom of tub after complete cycle. Called Bosch, they say it's normal to have some in bottom. I emailed them and was told the opposite that no water should be left inside and it should drain. Unit does drain water as I hear and can see it through sink strainer. I did have to add a hose extension because of my kitchen design; dishwasher is at 90 degree angle and 6 feet away from sink. So,,,,I had to add more hose. So,,,,my questions are:
1) is water in the tub normal?
2) Looking at the drain hose below, anyone have a better solution to add more length to the end, as I'm not satisfied with rigging the hose with an old dishwasher hose.
BOSCH Drain hose, shu
Thanks,
Vince
jdappl07
#2 Posted : Wednesday, October 31, 2007 5:00:12 PM(UTC)
jdappl07
lift the hose as high as you can and close to the dishwasher as possible and also keep the hose going down hill
