mbusch50
#1 Posted : Monday, May 9, 2011 9:29:01 AM(UTC)
mbusch50
Dear Sir:
The handle on my microwave door is loose. Can this handle be repaired or replaced. If so, what parts would I need and how would I do it?
Thank you.
Byron Busch
Joe / APP Team
#2 Posted : Monday, May 9, 2011 2:11:23 PM(UTC)
Joe / APP Team
Originally Posted by: mbusch50 Go to Quoted Post
Dear Sir:
Thank you.
Byron Busch
Byron,
The parts diagram,doesn't have a separate part number for the handle, only a complete door,
Part number: AP4238692
But as the handle is only loose, you should be able to dismantle the door, install a couple of flat washers and tighten it up, and save a lot of money ???
Grille Removal
The top full-width grille is removable for service to some
components, such as: humidity sensor, oven light, door
removal, flame sensor, vent motor capacitor, fuse,
control panel, and stirrer motor (some models).
Grille Removal
1. Disconnect power to oven.
2. Remove screws located in front on top of microwave securing grille.
Door Removal
1. Disconnect power to oven and remove grille, see "Grille Removal" procedure.
2. Open the oven door, slowly raise the door evenly, disengaging the pins at the top and bottom.
NOTE:
When aligning the door for assembly, the door must be opened as much as possible.
Door Disassembly
1. Disconnect power to oven and remove oven door, see "Door Removal" procedure.
2. Pry away choke cover, by placing a tool in the upper right corner of the door and gently prying outward on the choke cover. Continue to work around the door casing until choke cover is completely loose.
3. Slide latch assembly upward and to the left to release plastic tabs from door frame. Once latch assembly is loose the spring may be disconnected from the door frame.
4. Remove screws securing door frame assembly to door panel.
5. Remove door frame assembly by releasing tabs around entire door panel.
6. Remove door handle by removing screws securing handle to door panel.
NOTE:
The door handle can only be reinstalled by guiding the top and bottom insertion points into the correct receiving slots. It is impossible to reinstall the door handle "upside-down."
7. Remove door glass by releasing tab securing door glass baffle. Remove baffle, then slide door glass to the right slightly, then push the door glass upward to release the glass from the track.
8. Reassemble in reverse order.
Good Luck,
Crosley electric dryer door handle part number (Dryer Repair)
by Guest 10/22/2023 1:05:15 PM(UTC)
Need help with repair of Kenmore built in oven door handle repair 91141065791 (Oven Repair (including Ranges and Cooktops))
by Notacook 10/27/2021 5:49:46 PM(UTC)
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 8/9/2021 11:02:12 AM(UTC)
Dryer Model WED5000DW2 Need help on dryer door handle (Dryer Repair)
by tljohnsonrealtor@aol.com 11/1/2018 9:44:58 AM(UTC)
Tighten Door Handle (Refrigerator & Freezer Repair)
by BKWhite 12/24/2017 4:48:40 PM(UTC)
PVM9179SF1SS Door Handle (Microwave Repair)
by vesitmaverick 12/12/2017 6:14:43 AM(UTC)
Whirlpool microwave door handle broke (Microwave Repair)
by troyw66 11/9/2016 6:32:52 AM(UTC)
Door handle removal Hotpoint (Refrigerator & Freezer Repair)
by sierra101 4/20/2016 9:41:07 AM(UTC)
door handle (Refrigerator & Freezer Repair)
by jaj01 8/10/2015 3:52:56 AM(UTC)
How to Replace Outer Door Handle (Microwave Repair)
by sbiehler 7/14/2015 7:45:25 PM(UTC)
Microwave Door Handle (Microwave Repair)
by Dante77 7/7/2015 3:28:27 PM(UTC)
Replacing stainless steel door handle and plub (Refrigerator & Freezer Repair)
by famattjr 2/16/2015 10:22:17 AM(UTC)
Removing/Replacing Freezer Door Handle (Refrigerator & Freezer Repair)
by tightropewalkerr 12/1/2014 4:15:58 PM(UTC)
Door handle came off (Oven Repair (including Ranges and Cooktops))
by alex88 9/7/2014 7:29:00 AM(UTC)
Freezer door handle (Refrigerator & Freezer Repair)
by yamitibug 9/2/2014 10:20:22 AM(UTC)
