Look at the parts in Section 3.
You have several options Just the seal and pushnut Items 417 and 415 A seal & impeller kit Item 434 Or the pump assembly.
I would pull the pump apart before deciding what needs replacing. If the motor shaft is rusted you will nee a new pump. Could be it is time for a new unit.
First I would get in there with flashlight and a small mirror, to try and confirm that it is the seal that is leaking. It could actually be leaking higher up. Check the clamp Item 457. |
THIS FORUM IS DEAD!!!!!!! |
