my new apt has an electric self cleaning oven it has been working great but today while baking a code f3 came on the display i dont know why . I cancelled then tried turning on again and even changed the digital temp however it goes right back to f3 on the display
The oven needs a new temperature sensor. If you look in the back of the oven, up top in the left or right corner, you will see a thin rod. That is the sensor. That is what needs to be replaced. If you gave a model #, I would be able to give you a part#. Tom ApplianceEducator.com
