AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Frigidaire Freezer Coils Icing Up, Refrigerator side not cooling
Every 5 days or so the refrigerator side of the refrigerator is warm but the Freezer side is cold. When I remove the inside back panel, the freezer coils are filled with ice. I defrost the ice with a blow dryer and the refrigerator will work fine for about 5 to 10 days then the coils ice up again.
Here's a breakdown of your unit. Model FRS26ZRGW9 It sounds like the defrost timer or the defrost thermostat are out causing your issue. Nat
