hmoses
#1 Posted : Saturday, January 24, 2009 6:27:32 AM(UTC)
hmoses
I have a six burner stove with 2 xtra low burners. One of the xtra low will not light. It is the one we use the most. I assume I need to replace the controller. Is this correct and if so what is the part number so I can order. Thanks
#2 Posted : Sunday, January 25, 2009 2:34:13 PM(UTC)
Most likely the problem is a bad potentiometer. Thermador has redesigned the potentiometers and the controller. It comes as a potentiometer kit, contains of two potentiometers and controller.
- The part number for the potentiometer kit is AP3672574
Here are the break down diagrams for the Thermador range Model PRG366US
