dlstorch
#1 Posted : Friday, May 6, 2011 8:20:07 AM(UTC)
dlstorch
I purchased ice maker parts (auger sleeve, tray parts, fill cup and water inlet solenoid) from appliancepartspros.com. Received and installed all parts. The icemaker is not filling with water. The water in the door works fine. What else might I have missed in ordering parts?
Joe / APP Team
#2 Posted : Friday, May 6, 2011 8:50:49 AM(UTC)
Joe / APP Team
The ice maker control module(front assembly). or a loose connection or broken wire from the ice maker wall connection back to the fill valve. (a broken wire would be a non repairable situation).
I was unable to cross reference the model number you supplied, for a proper parts, but,
Part number: D7824706Q
Or
Part number: W10190935
Is the closest I can get without a "P" number from the production plate/serial tag.
Good Luck,
