lwalent
#1 Posted : Thursday, May 5, 2011 8:49:57 AM(UTC)
lwalent
I just replaced my belt on my Maytag dryer. Everything seemed to be working fine, (drum was turning and heat was being generated). I started to smell rubber. I turned off the dryer and opened the front panel and noticed the belt slipped off. I realized I didn't have the belt around the pulley correctly. Now my dryer will not turn on. Any suggestions?
#2 Posted : Thursday, May 5, 2011 1:22:33 PM(UTC)
A make and model number may help others help you.
Some units have a belt break switch on/near the idler wheel perhaps this is not being close, if your unit has one.
Have you tried shutting the breaker off/on slowly a couple times.
Many units have a thermal fuse mounted on the blower assembly perhaps this blew.
