roque13
#1 Posted : Thursday, January 22, 2009 2:13:37 PM(UTC)
roque13
dryer wont heat had the element tested and the thermostat tested they are fine what should i do next ??? thanks ..
Drags1998
#2 Posted : Thursday, January 22, 2009 3:25:07 PM(UTC)
Drags1998
Check BOTH CIRCUT BREAKERS for the dryer, Yeah,I know it will run, But check the BREAKERS!!!!:)
kayakcrzy
#3 Posted : Friday, January 23, 2009 4:41:57 AM(UTC)
kayakcrzy
Also check the thermal fuse, that is mounted on the element housing up top. Take the wires off, before you ohm it out. Don't forget to unplug the dryer when you do. Tom ApplianceEducator.com
