My washer keeps stopping mid-cycle. It has something to do with the switch - I used to be able to push down on the lid above the switch and it would resume the cycle.
It's gotten worse and now I have to push the switch down and put a plastic piece between the switch and the washer to keep it compressed. Even if I do this when I put a load in, it still keeps stopping mid-cycle (after the wash/before the rinse cycle stops).
Should I replace the switch? Is the timer having an issue also?
Replace the lid switch.
Nat
I thought so.
Glad it's not the timer at least.
Could you post the link to taking apart a washer? I remember seeing it before posted somewhere here.
Thanks!
Kathy
