WASHER WILL NOT GO INTO FAST SPIN CYCLE. WILL START TO SPIN SLOW STOP, THEN START AGAIN. BUT NEVER FAST. WILL ACT THIS WAY FOR ALL CYCLES.:confused:
Remove the front toe panel and check for the mini-manual. Perform the troubleshooting for the motor and the speed control board. I would suspect the speed control but this is expensive part and better to test it first. Here are the break down diagrams for the Gibson washer Model GWT445RFS2Gene.
