echo210
#1 Posted : Sunday, May 1, 2011 4:27:11 PM(UTC)
echo210
Hi, I have an Amana ADB1500AWW3 dishwasher and am having symptoms as if it's not getting power. When I press the Start button I see a very faint response in the 'Normal Wash' indicator light, but it's much fainter than I see when it's operating normally. Aside from that, there's no response at all from the dishwasher.
I have verified power at the wall and to the dishwasher, and have checked the two latch switches for continuity. When I manually lift the float in the tub, I hear what sounds like a relay tripping, but haven't delved under the unit to do any testing there. I also see the PC board in the black plastic enclosure next to the latch assembly, and am wondering if there's any way to test that for functionality. I fear I'm quickly getting out of my depth without further guidance.
Any help would be greatly appreciated.
#2 Posted : Tuesday, May 3, 2011 2:59:41 AM(UTC)
Replacement parts for ADB1500AWW3 models | AppliancePartsPros.com
First try unplugging/removing power from the unit for 5 minutes or so, to see if the control board will reset.
You could try the following cleaning procedure
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If the above does nothing the usual way to troubleshoot whether it is the keypad/control panel or control board is to check the keypad with a meter.
If it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
If you do the above tests then you may want to consider ordering from AppliancePartsPros. They will allow you to return a board if you do some basic troubleshooting and do not just order all possible parts and then just return those you do not need. See their return policy.
File Attachment(s):
ABD1500.pdf (120kb) downloaded 46 time(s).
