cheesey134
#1 Posted : Tuesday, January 20, 2009 1:04:23 PM(UTC)
cheesey134
I am changeing the upper drum glide and rear bearing every six months. The top glide wears out and the clothes get stuck between the front cover and the drum. Is it normal for the drum to rest all of it's front weight on the top glide? This time is the worst, the drum won't even turn. Usually it will just make a loud squell and I'd change it. Let it go to long this time. Ther is a yellow plastic block mounted to the houseing, on top in the front under the top cover. It looks like it should help guide the drum, but it does nothing. There's a duplicate one mounted on the lower rear of the houseing, this one lets the drum rest against it. Any help???
kayakcrzy
#2 Posted : Wednesday, January 21, 2009 4:34:58 AM(UTC)
kayakcrzy
You are correct. That is the drum glide, and it comes in an upper and lower piece. The part # is 5303937139 Tom
need new drum glides, part number? (Dryer Repair)
by Kyle 4/26/2015 11:16:19 AM(UTC)
Dryer Drum Glides make drum stick?? (Dryer Repair)
by Eyemalive 5/4/2013 10:23:54 AM(UTC)
Front Drum Glides (Dryer Repair)
by Tahoet2 12/21/2011 8:03:06 AM(UTC)
Drum glides (Dryer Repair)
by luvcrossstitchin 11/21/2011 6:27:03 AM(UTC)
Replacing Drum Glides And Felt (Dryer Repair)
by loria 3/12/2010 6:05:57 AM(UTC)
Dryer drum glides and bearings opinion? (Dryer Repair)
by pakmt 11/29/2009 4:17:55 AM(UTC)
