We just got the replacement glass from Appliance Parts Pros to go on the inside of our oven door. Could you please tell me how I can replace it correctly? Thanks! -Adair
Adair, Remove the door from the range as described in the Owners manual (page 27). Place the door on a flat surface with the door handle facing down. Remove the screws holding the door inner panel and then follow the break down diagram. Gene.
