When the refrigerator door is closd hard, the to freezer door opens slightly. How is this repaired.
The most obvious is don't close the door hard but if you have kids that will be impossible.
You may want to check the doors bottom hinge. Often there is a plastic cam here. Perhaps it is worn or damaged. As you close the door, it rides up the cam and then down the other side to help hold the door closed.
Also check the level of the fridge. Make sure side to side is level Front to back. Does not hurt to have it tilt slightly to the back. |
THIS FORUM IS DEAD!!!!!!! |
